Patch Lofting Segment Nodes Dynamically Editable!
mavigogun
Advisor Advisor
mavigogun
When Lofting in the Patch workspace, after I executed the Loft, one of the nodes would disassociate from the Sketch Point related to the Spline segment that propagated it.   Editing the Loft, I discovered the nodes in the loft can be dragged around the genitive Profile; when relocated to the associated Point, no new Loft seam is introduced- otherwise, a new seam is propagated.   Pretty **** useful for controlling how Loft Profiles join/preventing staggered seams.
schneik-adsk
...and if you double click and drag a node you will move all nodes proportionally.
Kevin Schneider
TrippyLighting
@schneik-adsk I always thought there is only one person I needed to kidnap for about a year to get proper documentation written. That was always @jeff_strater. However, you've now been added to my list. So watch out 😉
One day ....
jeff_strater
yeah, the "double click to edit all loft point mapping points at once" probably gets the prize for the most cleverly concealed feature in Fusion.  I did not know it was there until I created an enhancement request for something very similar, and Kevin pointed it out to me...
Jeff Strater
Engineering Director
