Draft Analysis Showing Errors on Simple Extrude
Hello all -- I'm a beginner, so please take it easy on me. Smiley Happy I've drawn a basic shape in Fusion 360, using the line tool, and then extruded it. When I view the draft analysis, most of the extrude shows up as red. So all subsequent modifications to the shape show up red as well.  Any ideas on what I'm doing wrong? My units are set to inches, and the extrude is set to exactly one inch. Thank you for any help you all can provide.
Screen Shot 2018-08-04 at 1.01.48 PM.pngScreen Shot 2018-08-04 at 12.57.31 PM.pngScreen Shot 2018-08-04 at 12.58.09 PM.png
TheCADWhisperer
I do not see anywhere in your problem description where you mention adding face draft (Taper Angle) to your part.
Can you File>Export and then Attach your *.f3d file here?
Thanks for the reply! I must have missed that step (face draft). The tutorial I was following didn't mention it. I've attached the .f3d file here. Any help you can provide is appreciated!
Thank you
TheCADWhisperer
What is the web link to the Tutorial?
It was this tutorial here: https://www.youtube.com/watch?v=A5bc9c3S12g
He started with a shape, whereas I started with (what I thought) was a face.
Thanks!
TheCADWhisperer
The last couple of word in that video - always fully define sketches.
I didn't see dimensions in your sketch?
