When did Sculpt leave the Pull-Down menu?
mavigogun
Advisor Advisor
mavigogun
The Sculpt Workspace is no longer on the pull-down menu.   When did that happen?
HughesTooling
It doesn't show on the pull down if you have record history enabled. Or are you using the new preview UI?
Mark
Mark Hughes
Owner, Hughes Tooling
mavigogun
Nope
Mark
Not using the new UI.    Was it ever on the pull down, once-upon-a-time, or am I miss-remembering?
HughesTooling
It's only ever been on the pull down menu if you're in direct edit mode. With the timeline you have to use Create Form to get access to the sculpt workspace.
Mark
Mark Hughes
