What would be the easiest/correct way to close this body?
Hi!
First of all, what would be the best way to convert the mesh to a body for manufacturing purposes?
Secondly, what is the correct way and could someone show me how to close the open part of the model? Added a pic to understand what I mean and I added my file below!
How to close this part?How to close this part?
I_Forge_KC
What is the difference between the mesh and the surface body in there? Closing up the surface body is pretty simple. closing up the mesh is a different story.
K. Cornett
Generative Design Consultant / Trainer
No difference, it's the same thing, I'm just wondering is there an easier/cleaner way to convert a mesh to brep, other than going through the hassle of making it a t-spline and then to brep.
Other than that how do I close the body, because when I try to add a patch to the body it just closes in a curve, but that's not what I'm looking for, could you help with this?
 Here it closes in a curve.Here it closes in a curve.
I_Forge_KC
You need to add a couple of lines (3D) and make separate patches to hook it all together.
Check it...
I added two sketches (could have been one). There is a vertical line on each side at the end and then the center "T" shape gets blocked off (because of a curvature problem otherwise).
This makes for some questionable surface curvature, for sure, but it is watertight.
K. Cornett
