What processor to buy for Fusion rendering?.
fprico
Message 1 of 86
fprico
I am between two proecessors the 9900k and the 3900x. I know that the 3900x have 12 cores vs 8, but I don't know how it works in fusion 360 as I don't have any benchmark. Will the 3900x be a lot faster in Fusion rendering?.
Replies (85)
Message 21 of 86
Yes, I have 3700x.
Message 22 of 86
Beyondforce
Or, you meant the I need to add the 3700 into the list?
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 23 of 86
Beyondforce
Sorry, I'll add 3700x right now!
Ben Korez
| YouTube
Message 24 of 86
Beyondforce
The 3700x is slightly better than the 8700.
Ben Korez
| YouTube
Message 25 of 86
fprico
Hi all,
I have created a scene for us to test rendering speed, the ilumination is not the best.. but anyone could change it if they want.
Here is the scene: https://a360.co/2Q7j6oJ
I have an old Intel quad core, rendering is to slow I am uprgrading to a ryzen 3950x or 3960x. the idea is if anyone is threre willing to test the performance in render viewport or image rendering. Let me know your thoughts.
Message 26 of 86
FernandoP3d
Here is the video.
<iframe width="640" height="590" src="https://screencast.autodesk.com/Embed/Timeline/3b25b6e8-ff38-4057-8964-717e0cd937a9" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 27 of 86
jasonhomrighaus
My Mac Pro 5,1 with the Dual 6 core chips has an effective 24 processor bank and every one of those puppies goes hot on rendering so im pretty sure it does do hyper threading.
Message 28 of 86
jasonhomrighaus
I can't seem to down load that scene, but if you share link I can try it on my new MacBook Pro.
if I ever get the Mac Pro 5,1 back in business I can rip it on there too.
Jason
Message 29 of 86
fprico
Hi, thanks
let me know if this link works: https://a360.co/2WffDIT
Download as fusion 360 file. You also have an option at the top right "Open in Fusion 360"
I will test it my self with a with an intel q8200 old Cpu.
Message 30 of 86
fprico
try a 1920 x 1080 render image render quality set to Final. So anyone could make the same.
Message 31 of 86
fprico
so is 24 cores 48 threads? 4 Cpu's of 6 cores? what year is the model?
Message 32 of 86
fprico
Takes me 84 minutes to render with my Intel Q8200 cpu 4 cores 4 threads 2.33ghz,  4gb of ram. Render settings: 1920px by 1080 px. Quality set to Final.
With a bit of photo editing:
Message 33 of 86
fprico
Would be good if someone or Autodesk could make a graphic program like cinebench.
Message 34 of 86
Beyondforce
Fusion doesn’t support hyper-threading and a CPU single-core speed is much more important than the number of cores! Even thou some operations are multi-core; e.g. Shell, Thicken, Interference Detection, Rendering and there are a few more. The speed per core will be a bigger advantage.
Ben Korez
| YouTube
Message 35 of 86
Beyondforce
Which is why I created tesreg.com.
Ben Korez
| YouTube
Message 36 of 86
TrippyLighting
Yep, spot on!
Message 37 of 86
fprico
Yes I am testing rendering here, It would be nice to have a rendering graphic benchmark too like cinebench that you could see the render in the window. I upload a scene to compare to any who wants. Blender community did the same they created a scene, Bmw, to test speed.
Message 38 of 86
Beyondforce
There are 3 tests in tesreg.com - Open file, FPS and Render.
The test file has been chosen carefully, it is not too complex and not too simple as well. There are also instructions on how to use the table, how to read the comparisons and what things you need to take into account in real life.
It will give you a good indication of what to expect if you choose CPU A or CPU B, and you could also add prices as well 😉
As soon as I have enough data, I'll also add more visual graphs. If something is not working for you, then please let me know!
Ben Korez
| YouTube
Message 39 of 86
fprico
Have you tested 3900x or 3960x in render?. I am referring to a graphic window where you could see the render in progressive refinement like in cinebench. Which processor do you have?.
Message 40 of 86
fprico
Here is the speed test of the 3900x in rendering.
https://youtu.be/qGiKJZd4kV4
Does anyone have 9900k, 10900x or any similar Intel chip to make a video of this simple render?.
