05:38 PM
If you have an assembly of say 10 components Top down modeled and each of these components is machined, you quite quickly end up with a complex file since most machining has fixtures, vices chucks etc all then modeled in this one file. Is this what is commonly done? Or the approach I took which is create the assembly then export out each component and create a separate machining file ( not ideal since the components are not linked).
I am interested as to what is regarded as good practice.
