what could have happened to my sketch such that I cannot move parts of it?
itchytoes
itchytoes
HI --
I have a sketch (screen shot attached),  and I can click the "Edit Sketch",  but for some reason, I cannot do anything about changing the rigth sdie.  For example, I can click on one of the dots and click "Move",  and I get the moving-thingie,  but moving it does nothing -- I just cannot move the points.
However, I can move points on the left side of the sketch.
What could I have done?
Betty
TrippyLighting
I don't see any constraints in the sketch. Are there any ?
For example is there a mirror constraint in your sketch ?
innovatenate
Autodesk Support
Autodesk Support
Could you share a public link of the design? You can do this by right click on the design right in the data panel and selecting Share Public Link....
Nathan Chandler
Principal Specialist
itchytoes
Hi --
Here's the shared link  http://a360.co/1NqWy6p
I don't think I have any symmetry constraints, but I might have added something and not know how I did it 🙂
Betty
donsmac
I looked at your file and right away had this happen when I selected a piece of geometry. Here's a screencast that shows some strange behavior.
innovatenate
Autodesk Support
Autodesk Support
Thanks for sharing the file. I am able to reproduce the behavior you described with the move command. Dragging doesn't seem to help either. I also try using the Move to Plane command, and even sketching a fresh spline.
At this time, I do not have an explanation for the behavior. I will report it to development (via report FUS-22349) and circle back with an update. Thank you for posting this!
Nathan Chandler
