I have a simple tripod that is constructed from three tapered cylinders as shown in the first image. After printing I have found that the join between the legs is fragile. I want to add webbing to increase the strength. I am not sure how to do this. I have tried sketching on webbing, with the idea of extruding it, but it doesn't join to the mesh. I would appreciate some pointers as to how achieve my outcome.
I am very grateful to those talented folk who can change my model to add the webbing. In this case I really want to know how to do it myself rather than having someone do it for me. I hope you understand!
Solved by wersy. Go to Solution.
Maybe like this?
And you can fillet it
Is it really that small?
In this size you will always have difficulties with printing in FDM.
Thanks - yes, it is that small - it is a model boat. The printing is surprising good, just needs a touch of strengthening.
What are the steps you took to add those filets? I would normally call them filets, but Fusion uses that term to the processing of adding material to the inside of a shape and removing from the outside of the shape to create a smooth edge.
What I have made are so-called gusset plates.
The plate between the two diagonal supports would be a triangular plate. I have made a cut-out so that it can be printed without support.
To draw the plates, a plane must be created through the axles.
If you don't necessarily want it to be based on a specific model, you could perhaps make it a little more elegant.
Instead of plates, I would then create larger transitions.
But this is only possible in surface mode.
