Wave Pattern Split Body - File attached
rhetteshleman
Message 1 of 10
rhetteshleman
I'm trying to create vertical slices to cut on CNC. I can get close by making a surface from the end face then rectangular pattern but it gets sloppy once I start splitting bodies. There has to be a cleaner way that is easily editable. If you click Redo you can see my failed attempts. Thanks for the guidance.
Replies (9)
Message 2 of 10
jhackney1972
Is this what you are looking for?  I must be misunderstanding the question because Split Body on a patterned sketch gives good results.  Model attached.
John Hackney, Retired
Message 3 of 10
KristianLaholm
Thicken of a surface body will give you a body with all edges normal (90deg).
Message 4 of 10
rhetteshleman
This is exactly what I was looking for. In fact, if you're the same @KristianLaholm that did a YouTube video over this topic I watched it a dozen times to get as far as I did. I appreciate the video and response.
Can you please elaborate on thicken of a surface body? As you can see I created the model directly from your Youtube video, however I wanted vertical slats as you have done here. A little more clarification would be great.
Thank you
Message 5 of 10
etfrench
Rectangular pattern starting with a line at the origin:
Or you can use a thin extrude to create gaps between the segments:
ETFrench
Message 6 of 10
KristianLaholm
Open the attached file in my reply and have a look.
I'm doing surface extrudes using the curved face as target (To Object)
Then a a pattern of the feature using Adjust.
And thicken (symmetric) all the new surface bodies.
This will give you the result like cnc cut "slabs"
Yes it's my video, thank you.
Message 7 of 10
jhackney1972
This process is what I proposed?  He obviously wants something different.
Message 8 of 10
Warmingup1953
it can add Dowels and nest at the same time....No idea why it's an Abandoned Child!
Edit: Oops Sorry I had the scale wrong:
Message 9 of 10
etfrench
Just a slightly different method of creating the cutting tools and showing other options for cutting.
Slicing and moving the bodies apart will give a slightly different appearance and larger design than removing sections and keeping the same overall width.
ETFrench
Message 10 of 10
rhetteshleman
I appreciate all the replies. Lots of different ways to accomplish this.
