第 1 条消息(共 12 条)
Warning: Sweep - Reference Failures - The operation failed due to coincident control points.
不适用
03-31-2021
01:09 PM
Hello again, after few problems with API scripts, I finally realized my "import from csv tool" and I can now have issues with the real design 😅.
- I created 2 sketches, one with a profile and one with a sweep path.
- I pushed Surface >> Sweep
- I filled the command with the following settings:
- I can see the object preview
- When I press "ok", few seconds later I got the following error:
Warning: Sweep2 1 Reference Failures
Try adjusting the values or changing the input geometry.
I really don't know why, I tried to find here in the forum and online, but I didn't get a clue 😣
I attached also the file if it could help to find out the issue
Luca
