Hey everyone
I have designed my roll cage after creating the 3d sketch using pipe command. The body is a joint one. I have used two different types of pipe cross-sections as given in SAE rulebook - primary member ( 1" outer dia. with section thickness 0.12" - shown below in green color) and secondary member (1 " outer dia. with section thickness 0.035 " - shown below in red color).
I have done proper tube notching and all my tube joints are very clean.
Then in the simulation for meshing, I have tried for absolute size from 4-12 mm and in local mesh control, I made the mesh pointer to finest level.
But there are meshing errors. I don't know why?
Is there any way to mesh such structures which consist tubes of different cross-sections in Fusion 360?
meshing errors
isometric view
