Wankel Rotary Engine
jmartcarvalho
Message 1 of 8
jmartcarvalho
Hello everyone!
I have a problem with an animation of an assembly that I made in Fusion 360. Could someone please help me?
It is the following: I designed a Wankel engine (I don't know if you know the engine in question ...) and I can't set the proper rotation in order the rotor travels the necessary path. If you do not know the engine in question, I will be able to send information about the work I am doing and / or how the engine works and, in parallel, better explain my difficulty.
I will await feedback.
My e-mail adress is: [email protected]
Thanks in advance:
João Carvalho.
Replies (7)
Message 2 of 8
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
Message 3 of 8
its a 3 to 2 ratio with the main shaft rotating at 3 and the rotor at 2 in the opposite or negative direction
Message 4 of 8
stevenpq
Observer
Observer
Hi, I was doing some research and I came across your video.
I like your work and have learnt some new things, but that is not how you draw the rotor and rotor housing.
This is done through an equation driven curve for both the rotor and the rotor housing.
Message 5 of 8
jmartcarvalho
Hi Steven...!
Greetings from Portugal.
Firstly I would like to thank you for trying to help me.
Secondly, you're probably right as far as the equation goes...!
To be honest, I stopped (and didn't finish this project...) a long time ago.
Maybe one of these days I'll come back to continue with....!
I want to reiterate your kind words and tips.
My best regards from Portugal:
João Carvalho.
Message 6 of 8
Khushsharma219
Community Visitor
Community Visitor
why  are u showin solidworks he made it in fusion 360
Message 7 of 8
TheCADWhisperer
@Khushsharma219
Can you show screen capture of where SolidWorks is indicated?
Message 8 of 8
Khushsharma219
Community Visitor
Community Visitor
Autodesk inventor*
