Wacom tablet support in latest Fusion360
fulcrumusa
fulcrumusa
Hi, I have a Wacom Intuos Pro table and lately I've been trying to use it with Fusion360. I read somewhere that Fusion360 does have support for the Wacom tablets but I am not sure whether that is true. My observation is that none of the Wacom specialized functions work. What I mean by "specilized functions" is that the Wacom software has special "Pan", "Zoom", or "Rotate" functions which don't do anything in Fusion360.
I can simulate the "Pan" and "Zoom" by re-assigning those buttons to actual keyboard key combinations but my question is what level of support does Fusion360 include?
Alternatively, is there a list of all the keyboard shortcuts supported by Fusion360? I am aware that some of the commands have shortcuts and they are listed next to the commands in the drop-downs. I am wanted to see *all* the shortcuts, including navigational ones.
Thank you for your help!
Phil.E
Thanks for posting.
First, for shortcuts, just check out our learning page.
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-F0491540-0324-470A-B651-2238D0EFAC30
Have you seen the help section? You can search for terms like "shortcuts". If you can't find something just let us know.
For Wacom:
There is a recent post that may have helpful information about settings:
http://forums.autodesk.com/t5/design-validate-document/is-anyone-successfully-using-a-wacom-cintiq-w...
You can search for solutions using the community search tool:
Wacom is not enabled in preferences by default. So first turn it on.
I hope this helps. Please let us know if you have any more questions.
Phil Eichmiller
Software Engineer
Quality Assurance
fulcrumusa
Hi, I actually did do the help search and neither "shortcut" nor "keyboard" returned any results at all. I think I even tries "Wacom". I also found the Wacom Cintiq topic and read through it but the Cintiq is very different from the Intuos lines.
However, I did not even see the Wacom option in the Preferences. I'll definitely try it. Thanks for the info.
fulcrumusa
As you can see from the attached image, I don't have the Wacom input option in my General preferences. Why would that be?
fangfr
Hi @fulcrumusa,
Sorry, there is a bit of difference about "Use Wacom device for gestures" option between Mac and Windows.
- On Windows, it has been turned-on. Fusion doesn't show it on Preferences dialog, any more.
- On Mac, it appears on Preferences dialog and turned-off by default. A user can pick it as per actual need.
I am using windows too, and have problems with using an old wacom bamboo (one of their older graphic tablets, that I can`t find in the internet anymore), and every time I try to use it with fusion, Fusion zooms out incredibly far, although the pen just hovered over the board. Do you have any idea why this is happening? I haven`t found a similar problem in the forums.
Thanks for reading!
