Hi All,
In intersection curve command, when I try to join two different sketches (like shown in attached figure). It only accepts 'one' curve from sketch-1 and than for sketch-2 you can select multiple curves. I have to use this command repeatedly by selecting different curves of sketch-1 while staying in the sketch command to make one complete intersection curve out of two sketches.
In Inventor or Catia, one can select complete sketches in one single command and resultantly would get a intersection curve out of them.
The problem doesnt end here, if I later on change one of the main sketches the intersection curve doesn't adopt to the change. Any help/guidance would be really appreciated !!
