Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Visible edges only when turning part
3 REPLIES 3
JJackrabbit
616 Views, 3 Replies
Hello
I standard have the view set to "shaded with visible edges only".
But once I rotate the part it switches to shaded. When I stop turning it takes a couple of seconds to return to "visible edges only".
When I'm turning the part and set it to "shaded with visible edges only", it works. But switches back to "shaded"  the next time.
Where can I find this setting?
3 REPLIES 3
jeff_strater
in reply to: JJackrabbit
This behavior is not a setting.  It is done to optimize performance.  When you are actively doing a view operation, Fusion suppresses display of the edges, so that the view rotation can be smoother.  When the rotation stops, the edges are drawn again.  There is no way to change this behavior.
Jeff Strater
Engineering Director
JJackrabbit
in reply to: jeff_strater
Thanks for the explanation Jeff
JJackrabbit
Bit strange though because sometimes it just shows the edges perfectly fine?
Technology Administrators
