Hello
I standard have the view set to "shaded with visible edges only".
But once I rotate the part it switches to shaded. When I stop turning it takes a couple of seconds to return to "visible edges only".
When I'm turning the part and set it to "shaded with visible edges only", it works. But switches back to "shaded" the next time.
Where can I find this setting?
This behavior is not a setting. It is done to optimize performance. When you are actively doing a view operation, Fusion suppresses display of the edges, so that the view rotation can be smoother. When the rotation stops, the edges are drawn again. There is no way to change this behavior.
Bit strange though because sometimes it just shows the edges perfectly fine?
