I saw this today. In some instances, the visibility icon (light bulb) switches spots with the drop-down arrow in the browser when you mouse over it. This appears to happen when the name of a component is longer than the allotted character count.
If one attempts to click on the visibility icon, the result is to open the component's tree. It can then be quite tricky to turn visibility on or off, as the icon is moving around. See the attached Screencast.
I realize that visibility can be toggled with the "v" key, but I wanted to make note of this. I believe that it is a new issue.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
