Can't Save as
Can't Save as
luis_andueza
Advisor Advisor
Can't Save as
luis_andueza
Hello Everyone,
I am having an issue, I created a new project, worked with a file, now I am trying to copy that file to a shared folder, but when I try to Save as, I only can do it on the active project, and the shared project does not appear and also all my other projects are disable to chose it.
Also I can't copy the file to another project, it happens the same, does not appear the shared project and my other projects are disable.
I have try the same with other prjects and works fine.
Any idea anyone.
Thanks and regards.
Luis José Andueza Castro
Ing. Mecánico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
HughesTooling
If the design has linked components you can't save to another project. The only workaround I know is use the dashboard in your internet browser and download the main assembly, when you download the top assembly you get an f3z file that contains all the linked designs as well. When you have the f3z file upload it using the data panel in Fusion to the new project.
Mark
Mark Hughes
Owner, Hughes Tooling
luis_andueza
That's what I had to do.
I guess i have a reference somewere,
Thank you.
