Visibility Icon Bug
Visibility Icon Bug
neljoshua
Advisor Advisor
Visibility Icon Bug
neljoshua
I saw this today.  In some instances, the visibility icon (light bulb) switches spots with the drop-down arrow in the browser when you mouse over it.  This appears to happen when the name of a component is longer than the allotted character count.
If one attempts to click on the visibility icon, the result is to open the component's tree.  It can then be quite tricky to turn visibility on or off, as the icon is moving around.  See the attached Screencast.
I realize that visibility can be toggled with the "v" key, but I wanted to make note of this.  I believe that it is a new issue.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
jeff_strater
This is a known issue.  You can work around it by just expanding the browser to be wider.  We are working on a more general solution to the problem.
Thanks for reporting this.
Jeff
Jeff Strater
Engineering Director
jeff_strater
FYI - I think this is the same problem:  problem-moving-light-bulbs.  Sadly, it has not been fixed as quickly as I had hoped.
Jeff
Jeff Strater
neljoshua
Thanks for the note.  Glad to hear it is being worked on.
__
