Viewing dimensions
Viewing dimensions
Viewing dimensions
Ideally I would liek to export my model with all dimensions, but it seems that is not possible with fusion 360??
Can anyone tell me the best way to show dimensions on screen to screenshot or possibly export a PDF with them?
etfrench
What format are you exporting?
You can turn visibility of inactive sketch dimensions on by right clicking on the sketch and selecting 'Show dimension' from the context menu.
You can also create drawings which can be saved as pdfs.
ETFrench
Any format, ideally I wanted a PDF export with all dimensions. Suppose I will try your methods
TrippyLighting
If you are looking for "real" PMI dimensions then that cannot be done in Fusion 360. You can achieve "some" form of it through a workaround as described by @etfrench
