Spur gear add-in
Spur gear add-in
Spur gear add-in
Hi Fusion 360 team,
I was recently using the spur gear generator add-in but it creats me a new component and not a new body. But that is a problem for me because I need to put another spur gear on top of the one I've just created and then combining them in a single component to be manufactured. Can you add a simple button to the add-in so that I can choose what to create, a body or a component.
Thank you very much.
Mirko
etfrench
Use the Combine tool to join the two gears together
OR
In the Browser, drag and drop the second gear into the first gear's component
OR
Use a joint to align both gears
AND
See Rule #1
ETFrench
