View/Select Hidden Axis
Zero__
Zero__
Hi guys - new to Fusion 360. Just trying to measure the distance between two holes, but I can't seem to either view or select the central axis of a hole. I've been digging through the help articles for an hour and haven't found a method. How do I do either of these things? Thanks!
Intern, Pier 9 Lab, Summer 2015
Oceanconcepts
Being able to do this without creating an additional feature to snap to (a constuction line- axis) is a problem addressed in this idea station post:
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/improvements-to-the-measure-tool/idi-...
- Ron
Mostly Mac- currently M1 MacBook Pro
As Ron said, you can make a construction line axis, I believe there is one that will go to the cylinder center.  Here is an illustration from the same question that was answered before:
http://forums.autodesk.com/t5/design-and-documentation/selecting-centers-for-measure/m-p/5570176/hig...
Jesse
Zero__
Thanks guys. A little different from the NX and Solidworks that I'm used to, but that should work!
Zero__
Considering those posts are from nearly two years ago, I'm surprised that it doesn't seem to have been fixed. NX measure tool auto generates hidden axes when you hover over a hole. I've been spoiled.
That being said, I'm really impressed with Fusion so far. Sure beats Solidworks, though that's not really saying anything.
Oceanconcepts
Fusion has gone through tremendous changes in the last couple of years- I’m disappointed as well that the Measure tool doesn’t have the same snaps that the joint tool does. But knowing how responsive the Fusion team has been generally, I can only assume there is an underlying reason. I had the same complaint about aligning components and bodies, that was addressed, and we now have a good align function. I think you will find Fusion to sometime require a different approach, but to be very powerful.
- Ron
