Selecting centers for measure
- Mute
- Permalink
- Report
Hi, I'm having some issues with the Inspect tool which I hope you can help me with.
Most of the time when I want to measure somethin, I want to find the distance between some features. So if I select the endpoint of a line, and the another endpoint, all is good (but you could make XYZ visible by default, which I believe is suggested already in the Idea station). Ok, say I want to measure the distance between two holes, that also works. I just select the to circles, and the Inspect tool gives me the distance from center to center. This is just what I show in the first part of the little screencast below. But if I want to measure how far a circle is from an edge, I cant select the center of the circle. See the last part of the screencast. Now I will only measure the shortest distance between the circumference of the hole and the edge.
So, if this is not possible now, there should be some way to control whether you select the center or the circumference. Also, there should be a way to get a certex on the center of a line, and possibly some other features that I can't think of right now.
Kjell
