In some cases I don't seem to be able to access the bottom view icons when I load a project, is this a bug ?
thanks,
Hans
thanks,
Hans
Solved by josef.kucera. Go to Solution.
Hi Jamie,
It seems to be random, the icons are still there on the bottom of the screen but when you click on 'm nothing happens, you don't have access to the submenus. This is something I see on some other parts as well in F360 from time to time. In this case it happens most on imported files (step files).
thanks,
Hans
Hi Jamie,
thanks,
Hans
Hi hansvaneven,
I have also seen it randomly. There is a work around how I solve it when it happens, I just resize a little bit Fusion window and that fix the problem with Navigation bar.
Hope it helps a little bit.
Josef
Hi hansvaneven,
Josef
Thanks Josef for the workaround!
cheers,
Hans
cheers,
Hans
