View icons don't work
4 REPLIES 4
hansvaneven
545 Views, 4 Replies
In some cases I don't seem to be able to access the bottom view icons when I load a project, is this a bug ?
thanks,
Hans
4 REPLIES 4
hey Hans, can you give us a little more info. what seems to be the conditions where you are or aren't seeing the Navigation bar (view icons). is it consistent or random?
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Hi Jamie,
It seems to be random, the icons are still there on the bottom of the screen but when you click on 'm nothing happens, you don't have access to the submenus. This is something I see on some other parts as well in F360 from time to time. In this case it happens most on imported files (step files).
thanks,
Hans
josef.kucera
in reply to: hansvaneven
Hi hansvaneven,
I have also seen it randomly. There is a work around how I solve it when it happens, I just resize a little bit Fusion window and that fix the problem with Navigation bar.
Hope it helps a little bit.
Josef
Josef Kucera
Fusion QA
hansvaneven
in reply to: josef.kucera
Thanks Josef for the workaround!
cheers,
Hans
