Vice Not Working Properly
cmmpro1
Message 1 of 9
cmmpro1
Good morning,
I am starting a machining project where I will place the part into a vice to program around it. However, the jaw on the vice will not move or should I say, not flexible. How do I fix/modify that? I know how to do in InventorHSM but I need this for Fusion. Thank you for any help I receive on this.
Replies (8)
Message 2 of 9
davebYYPCU
Short answer is to assemble it on the base with Slider Joint.
Message 3 of 9
cmmpro1
Good morning,
I tried the slider joint thing but it looks like this vise need a complete redo to get this to work. I am lost and mad at myself. Can someone send me some instructions on how to do this? I am better at reading and following directions than looking at videos. Thanks a million!!
Message 4 of 9
jeff_strater
@cmmpro1, if you are willing to share your design here, it will be much easier to describe a joint scheme that will work for your design.
Jeff Strater
Engineering Director
Message 5 of 9
cmmpro1
I have posted the vice that I'm having trouble with. Thank you for helping me!!!
Message 6 of 9
jeff_strater
Thanks for the design, @cmmpro1.  I'll try to take a crack at this today.  The first thing I noticed is that your design contains only bodies, no components.  You need components to make joints.  So, the very first step is to use the "Create Components From Bodies" command:
Then, we can define the joints for this model, between components:
Jeff Strater
Message 7 of 9
cmmpro1
Thank you! I am going to continue to work it so I can learn this. What ever info you supply will be much appreciated.
Message 8 of 9
jeff_strater
Here is how I would go about the joints for this model.  The basic idea is:
  1. Create Components from Bodies
  2. Capture Design History (so that you can use As-Built Joints)
  3. Define Rigid Groups for a few subsets of the components that move together
  4. Ground the base component
  5. Define a Slider joint for the jaw that moves
  6. Define a Revolute joint for the shaft
  7. Create a Motion Link between the Slider and the the Revolute joints
Finished model is attached.   Here is a screencast:
Hope this helps you make progress
Jeff Strater
Message 9 of 9
cmmpro1
Thank you!!! That was fast!!!. I am going to try it on another vice to see if I can do it.
