Using the mirrored component ONLY in a sheet metal production work flow
Luke_Parf
Message 1 of 18
Luke_Parf
Hi all,
We have recently adopted Fusion 360 as the standard CAD package for design & manufacturing.
One thing I have found rather tricky is using mirrored components in a sheet metal workflow.
Say I have a library of products and a library of parts for those products. If I make a design change to a part I also want Fusion to make that change across the 10 other products that use it in my library.
In the situation where the product I am creating uses the mirrored version of a component ONLY, as in the non-mirrored version is not present in the model space. Is there any way I can insert just the mirrored version in to the design view?
Inserting the part > mirroring the part > deleting the non-mirrored version will of course delete the mirrored part also because there is nothing to reference.
Next best thing I can think up is inserting the part > mirroring it > hiding the original but that of course messes up the BOM.
NB: I can't save the mirrored version as its own dedicated part as it would be unproductive to have to make the same change on two different parts.
Any insights do let me know. Thanks!
Replies (17)
Message 2 of 18
HughesTooling
Have you tried Derive?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 18
Luke_Parf
Hi Hugh,
This works to an extent but I still seem to have to save the mirrored component as "Part no. - Mirrored".
Would be great to have an option that doesn't require so many extra steps when working with a parts library with hundreds of parts.
Thank you for your response!
Luke
Message 4 of 18
TheCADWhisperer
Remove, not Delete.
Can you Attach example for demonstration?
Message 5 of 18
Luke_Parf
Of course, find example file attached.
Though I had considered this, and I don't think the remove function works on external components.
Thanks for your response.
Luke
Message 6 of 18
TheCADWhisperer
@Luke_Parf wrote:
We have recently adopted Fusion 360 as the standard CAD package ...
This should be interesting.
Edit 1: I stand corrected - it looks like @HughesTooling found the Remove.
Edit 2: Or maybe not - I am still not seeing as I would expect.
After experimenting with this in Fusion 360 - I have come to the conclusion that you should have adopted Autodesk Inventor Professional instead - where this is trivial to accomplish.
Message 7 of 18
HughesTooling
Luke
You can remove an inserted part, what's not obvious is you need to right click the insert feature in the timeline and remove. The remove feature will be created after the timeline pointer not where you've selected the insert feature.
Mark
Mark Hughes
Message 8 of 18
HughesTooling
Here's remove used with your file.
Mark Hughes
Message 9 of 18
HughesTooling
@Luke_Parf  What I was thinking about using Derive was have a library design with both versions then use derive to insert whichever version you want.
So create your library design like this with each part named then when you use derive you can just select the component you want.
Mark Hughes
Message 10 of 18
Luke_Parf
Hi HughesTooling,
Well it's good that the remove tool is nowhere near any of the other remove tools.
Thank you for finding this. I like your suggestion on file area setup and will trial that out.
One note - When I remove the part body in this way I get a warning on screen saying:
"You are removing the last instance of an external component. Changes to this component will no longer be automatically updated in this design"
I'll have a play around with it and see whether updates to the root part appear in the mirrored part.
Thanks again, it's much appreciated.
Luke
Message 11 of 18
TheCADWhisperer
@HughesTooling
Can you Attach files?
Message 12 of 18
Luke_Parf
Hi CadWhisperer,
I did get a laugh out of the "Should have used Inventor" bit. Thank you for your assistance also.
Luke
Message 13 of 18
HughesTooling
@Luke_Parf wrote:
Hi HughesTooling,
Luke
@Luke_Parf  After modifying the source file you just need to roll the timeline back before the remove feature then update
Just update with the design in this state.
@TheCADWhisperer Did you just want the design with the remove? All I did was right click in the timeline and select remove, timeline marker after the mirror.
Mark Hughes
Message 14 of 18
TheCADWhisperer
Here is the behavior that I am expecting to see:
1. I create a Left Hand Component.
2. I derive that component into new file Right Hand Component.  (Preferably as Mirrored - but that option not avialable.)
3. Since Derived Mirror option not available I expect to Mirror the Component (or Body) and then Remove the original Derived.
4. Any change to Step 1 Left Hand Component geometry (for example, dimensioning the Hole location at a logical location) associatively updates in the derived mirror Right Hand Component.  This all works pretty seamlessly in the other MCAD softwares that I use.
Message 15 of 18
HughesTooling
@TheCADWhisperer  Here's a screencast working with a linked design, derive should work the same.
Mark
Mark Hughes
Message 16 of 18
TheCADWhisperer
Can someone post example files?
Anyone.
Message 17 of 18
HughesTooling
Attached file is the same as post #5 with the inserted design removed.
Mark
Mark Hughes
Message 18 of 18
TheCADWhisperer
Thanks, now I need to find the time to experiment.
All of a sudden work has piled up on me.  (The real paying job work.)  😓
