Using the mirrored component ONLY in a sheet metal production work flow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
We have recently adopted Fusion 360 as the standard CAD package for design & manufacturing.
One thing I have found rather tricky is using mirrored components in a sheet metal workflow.
Say I have a library of products and a library of parts for those products. If I make a design change to a part I also want Fusion to make that change across the 10 other products that use it in my library.
In the situation where the product I am creating uses the mirrored version of a component ONLY, as in the non-mirrored version is not present in the model space. Is there any way I can insert just the mirrored version in to the design view?
Inserting the part > mirroring the part > deleting the non-mirrored version will of course delete the mirrored part also because there is nothing to reference.
Next best thing I can think up is inserting the part > mirroring it > hiding the original but that of course messes up the BOM.
NB: I can't save the mirrored version as its own dedicated part as it would be unproductive to have to make the same change on two different parts.
Any insights do let me know. Thanks!
