Using parameters to resize a derived body or component
pcsentinel
pcsentinel
Is there already a way or is it on the roadmap (and if so for when) to do the following:
create a body with its length driven by a named parameter.
derive that body into another design
change the length in the new design
Without breaking the link.
jeff_strater
No, there is no way to do that today, in a Derived design (other than in some limited cases, for instance, by cutting length from the Derived design, or adding another Extrude to make it longer, but those options are very limited).  Yes, that is on the roadmap (in a slightly different form).  We are currently in the middle of developing "Configurations", which will allow you to set up a table of parameter values from a single design, and drive multiple sizes of that single design for use in other designs, or to make drawings, or Derive, etc.
Jeff Strater
Engineering Director
pcsentinel
That’s great to hear, sure it will help a lot of users. Thanks for the prompt reply.
