Using one profile for many sweeps in fusion?
Hello, I'm learning my way around fusion, and i was hoping to get some advice.
Is it possible to use one profile for multiple sweeps? I am designing something that will be constructed out of square tubing, but i am not entirely certain of the dimensions of the tube that will be available. What i have done so far is to make different paths then sketch the profile of the tube and reference 3 variables for height, width, and wall thickness to make it easy to alter, but having to repeat the profile sketch over and over for every new path i want to sweep seems inefficient.
I would guess there is an easy solution.
thanks for the advice.
jayden
A side question. So far i have not yet found a robust tutorial series to really get familiar with Fusion, Lynda.com style, what is the best resource out there for getting a solid grasp on the ins and outs of Fusion?
LMD001
Hello Jayden,
Next to the sketches in the browser there is a lightbulb, when a sketch is consumed the bulb goes out, click on the bulb to see your sketch again and reuse with other sweep paths.
Fusion 360 on you tube is a good resource.
Hope this helps.
Best regards,
Ludo
LMD001
Hi Jayden,
Looked up the address: https://www.youtube.com/user/AutodeskFusion360
Best.
-Ludo
Thanks for your help!
Ok, i figured that the solution would be along those lines.
Follow up questions, when i do that, i need to make the path sketch alongside the profile sketch then move the new body after the sweep, correct?
I can't make my path where i want my new body, then in the sweep dialogue reference a profile that is not in contact with the path or is there a way to change that?
verry greatful for sucha  quick response!
LMD001
Hello Jayden,
Moving the new body is a way of doing this, for quickly checking out some designs this will work OK! If you want to test different profiles, each will need a sketch.
The Sweep command will come back with a warning if the path is not connected to the profile, it is a good practice to connect profile and path. I think some paths will work even when not connected.
Best regards,
Ludo
Thanks for the advice!  I did some sweeping all my new bodies at the origin with the same profile then move them to place.
As i recall 3DSMax let you use a profile with a path regardless of the position to eachother.
I hoped that there would be a similar option in Fusion, but building at origin then moving works just fine.
thanks again,
jayden
