Project Sketch is a new one to me 🙂 I have done as you suggest and it achieves the same result as before - the top right corner is not rounded correctly.
What I want to acheive is a scaled down version. I have tried scale which works great, but then when I go to edit the scaled sketch it jumps back up to the size it was before the scaling factor? Now that I am aware of the Project Sketch funtion I have come up withe the following work flow that achieves what I want:
Edit original Sketch.
Select all, right click, Copy.
Close Sketch.
Create new sketch.
Paste.
Close Sketch.
Create new sketch.
Project intermidiate scaled sketch.
Close Sketch.
Delete intermidiate scaled sketch.
I now have the original sketch intact and I have a scaled version that I can work with. Now when I edit the new sketch is remains at the scaled size because it is no longer a scaled sketch but a projected version of the scaled sketch that is now deleted. I'm sorry if I confused you with all of this.
If you have a better solution let me know, if no better solution also let me know and I will simply set this thread to "Solved".
Edit: This poses a new problem. I can't seem to move, edit or select this new projected sketch?
Mark
