Using axis as reference
I am a bit new with this CAD software.
I checked already a lot of tuto on Youtube but I can not find the solution to my issue.
I am trying to using an axis as reference for a sketch
Please check the picture I want to put a dimeunsion between the axis and one side of my rectangle
davebYYPCU
Edit the circles’ sketch and dimension the centre point.
Might help....
laughingcreek
You don't really need the axis.
-"edit" the sketch with the square
-"project" the center point of the circle into the sketch
-dimension the side of the square off the projected point
Thank you. I was not able to project the center of the hole but at least the axis.. So it is not so bad 😄
g-andresen
Hi Denis,
there are several ways to goal:
1. project axis
2. project centerpoint
project axis and centerpointproject axis and centerpoint
3. project contour
project contourproject contour
regards
günther
