How will fusion 360 run with Uhd graphics
fprico
fprico
I am planning to buy a levono ideapad 330s it comes with Uhd 620 graphics. How would it run Fusion 360 in it. I saw a video that it runs very laggy. but the test its with and old hd graphics. here is the video:
https://www.youtube.com/watch?v=0rBcCJzsKz4&t=599s
thanks.
lichtzeichenanlage
I wouldn't say this is a good idea. Beside the missing gfx card, your machine of choice comes with a variate of CPUs. Down to a Pentium processor.
Check the minimum hardware requirements
fprico
Hi, the laptop I am looking for is an i7  8 gen. 8550u
lichtzeichenanlage
But it still doesn't match the minimum hardware requirements. Have you checked the link? It looks like Fusion 360 requires a gfx card with dedicated memory. Fusion 360 pushes a lot of work to one core, some work it distributes to all cores but it still has to visualize the data.
fprico
I am looking at an hp model with 12gb of ram  i7 8550u 8 generation 4c 8t up to 4ghz and an mx150 geforce 4gb. how would fusion run on it. Will it run decently.
TrippyLighting
You should not have any problem running Fusion 360 on that machine.
lichtzeichenanlage
That really depends on what you want to do. I'm a hobbyist. I'm 3d printing more or less everything I'm designing. RC, tools, smart helpers ... things like that. I'm fine with my old Lenovo T520 from 2011.
If I compare the CPUs the 8550u is a bit faster but I'm not sure how this comes into play with Fusion. Your base clock speed is a bit slower, the turbo speed is a bit faster. Now it depends how Fusion 360 works with this.
If I compare the gfx cards your card is again slightly faster. Edit: This time the difference is bigger.
