Using a parameter in a dimension
truher
Message 1 of 11
truher
Sometimes, when I use a parameter name as a dimension, the parameter is "live," i.e. changing it in the parameters table changes the dimension.  For example, I make a parameter called "length" and use the word "length" as the dimension for some sketch line.  Changing the "length" parameter in the table will, in fact, change the length of the line.
But other times, Fusion seems to take the *current* value of that parameter, and that's all.  Changing the "length" parameter in the table *will do nothing.*
Is this a known bug?  Is there a workaround?
Replies (10)
Message 2 of 11
jhackney1972
Can you please attach am file that contains a parameter that behaves in this manor.  I know you said it is sporadic but Autodesk will want to have an example of this in order to determine the problem and solution.
John Hackney, Retired
Message 3 of 11
truher
if i can make a minimal example, i'll attach it.
note my question was:
"Is this a known bug? Is there a workaround?"
is there a bug database somewhere that we can see?
Message 4 of 11
TrippyLighting
No
No
Message 5 of 11
truher
No
Given your answer below, how do you know?  Do you mean you haven't personally bumped into it?
No
Why not?  It's common for tools vendors to want a way to collaborate on deciding what's important to fix.
Message 6 of 11
jeff_strater
I agree with @TrippyLighting 's assessment here.  We keep a close watch on this and other forums, as well as customer support, in addition to doing extensive testing on our own.  To the best of my knowledge, I am unaware of any cases, in a parametric design and a parametric sketch, where a dimension that references a parameter does not update if the parameter is changed.  Again:  in a parametric sketch.  If you have a sketch that was created in a Base Feature, or a Form Feature, that sketch is not parametric, and will not associatively update with parameter changes.  Again, if you have a case that shows this, that would be helpful in fixing it.
No
Autodesk, as a policy, does not let outside people have access to the bug database.  There are many reasons, one of which is IP protection.  The bugs often contain source code, or detailed architectural descriptions that would not be appropriate to reveal to the outside world.
Jeff Strater
Engineering Director
Message 7 of 11
TrippyLighting
@jeff_strater wrote:
Autodesk, as a policy, does not let outside people have access to the bug database.  There are many reasons, one of which is IP protection.  The bugs often contain source code or detailed architectural descriptions that would not be appropriate to reveal to the outside world.
I've used a good range of 2D and 3D CAD software professionally for over 3 decades. I am not aware of anyone sharing their database with bugs and priorities.
Message 8 of 11
HughesTooling
Never seen any problems like this with sketch dimension but I have seen problems with patterns where you use a parameter when you create the pattern but when you go back only the number is stored, not the parameter. Most of these bugs have been fixed but you might have found one that hasn't. Please share a design if you can repeat the problem.
Mark Hughes
Owner, Hughes Tooling
Message 9 of 11
mcarland2G36H
Community Visitor
Community Visitor
I just ran into this. If you edit the only sketch, the outside border should be wall_thickness, and the inside border floor_edge. The left side of the opening is using floor_edge, but when you try and change the right side 3.00 value to floor_edge, it stays 3.00. Same with trying to change some of the 4.00 values to wall_thickness. They were originally correct when they started out as offsets, but when the lines were broken/trimmed to make the opening at the bottom, I could no longer assign the parameters to the dimension.
Message 10 of 11
scottprater
Hey Mcarland,
I did some fiddling around in your sketch. When I tried deleting the right side "floor edge" dimension and re assigning it, it flagged an "over constrained" error. I checked all the other 3mm and 4mm dimensions and deleted all the ones that were over constrained, and then added back the constraints and dimensions that were needed to fully define the part (mostly just horizontal/vertical constraints). It seems to be working correctly now. Here is a screen shot of my final sketch.
My theory; when you created your offsets and trimmed up your sketch, a lot of your previously assigned dimensions were now over-defining, and Fusion doesn't allow you to assign parameters to over-defined dimensions. You can get your sketch to work by deleting all of the over defined dimensions; you should only really need 1 dimension each to drive both the wall thickness and the floor height (though I'm not sure why it thinks the floor height dimension is needed twice).
Maybe this is the same issue the OP is running into?
Message 11 of 11
mcarland2G36H
Community Visitor
Community Visitor
Thank you!
I didn't notice it reporting the over constrained error. Both of those lines started out as offsets to the main loop, so I had only dimensioned them once. The other values appeared when I started trimming, I believe.
I'll clean it up as you suggested, I'm sure that will resolve my issue.
Thanks again.
