Using a base component to create variants and having those variants be affected by changes to the base model but not vice versa.
reginaldgaribaldi
Message 1 of 11
reginaldgaribaldi
Sorry for the overly complex title. I'm not sure how to word exactly what I want and my searches have been fruitless.
The situation is this:
I have a component that is a wall. It has a regularly spaced brick pattern with a recess between the bricks. Easy enough.
I want to use this component as a base for designing variants on this wall with windows, recessed areas, doors, etc.
I want to be able to reference this original wall model so that, if in future, I decide I want to change the width or depth of the brick spacing, or make any other changes to the base wall design, these are propogated through to my variants.
I do not want the changes made to my variants to affect my base wall design.
I cannot find an effective way to achieve this. Is there one or am I wasting my time and should just create copies of the base component and make any changes across my variants manually?
I hope that makes sense. I've been puzzling over this, searching google, and trying different things for a couple of days now but nothing seems to work the way I want.
Replies (10)
Message 2 of 11
g-andresen
1. rightclick > save copy as (my wall)
2. create and save a new design
3. insert "my wall" from datapanel
4. if needed > rightclick > break link (chain symbol)
5. edit "wall"
günther
Message 3 of 11
reginaldgaribaldi
Thanks for your reply Günther!
So is there no way to achieve this without having the base item or variants on a seperate design?
Dean
Message 4 of 11
g-andresen
Just take a look at this Tutorial  by @jhackney1972
günther
Message 5 of 11
reginaldgaribaldi
Having tried both I found Jhhackneys solution not to work. Presumably this is something that changed between software versions.
Your original solution Günther appears to be the only way forward.
Thanks again.
Message 6 of 11
jeff_strater
I think what you really want is "configurations".  This will allow you to create a "family of designs" based on a single parametric design.  This capability is currently under development in Fusion.  To get a preview, you can join the Fusion 360 Insider Program
Jeff Strater
Engineering Director
Message 7 of 11
reginaldgaribaldi
Thanks Jeff, this does seem like exactly what I would need but I'd rather wait until it is in a release state than risk losing work by using a pre-release build.
Message 8 of 11
TheCADWhisperer
@reginaldgaribaldi wrote:
I want to be able to reference this original wall model so that, if in future, I decide I want to change the width or depth of the brick spacing, or make any other changes to the base wall design, these are propagated through to my variants.
This sounds exactly like Derived Component (not Configurations) to me?  At least how Derived Components work in other CAD software - I have not used in Fusion 360.
Message 9 of 11
reginaldgaribaldi
On further review neither of these solutions seem to work.
With your original solution I cannot manipulate the inserted component in any way. I can add onto it but cannot change the geometry of the original part in any way. No cuts, no fillets, nothing. The body may as well not be there for anything other than reference.
I can only manipulate it after breaking the link which defeats the original purpose.
J Hackneys solution does not work either. I followed his steps exactly with a basic shape in a new design and the component created as a result of the boundary fill tool is not in any way affected by changes to the original component.
Back to square one.
If anyone else has any insight please let me know.
Regards
Dean
Message 10 of 11
TheCADWhisperer
Back to square one.
@reginaldgaribaldi
I just tried Derived Component and it works exactly like described in your problem description.
Any edits to the base source propagate through all Derived Components.
Changes to the Derived Components have no effect on the base source.
So easy. So logical.
Message 11 of 11
reginaldgaribaldi
You're right! This is exactly what I needed and I don't know how I missed this function.
You're a lifesaver, thank you.
