User Parameters
User Parameters
eod9910
Message 1 of 8
User Parameters
eod9910
I can't find the user paremeters command in the modify panel. Please help.
Replies (7)
Message 2 of 8
jeff_strater
It should be at the very bottom:
Do you not see it there?
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 3 of 8
eod9910
No sorry. Here is a pic of the menu.
Message 4 of 8
jeff_strater
sorry, but did you by any chance forget to add the picture?  I certainly believe you that the command is not there.
One thing to try, use this command:
to reset your toolbar.  If that doesn't work, try:
Jeff
Jeff Strater
Message 5 of 8
eod9910
Ok this is weird. I closed 360 and reopened it and created a new blank
project. The parameters command is in the new project. Then I reopened my
old project and it was still not there. So I inserted the the project into
the new blank project and it seems to be ok. A bug?
Message 6 of 8
eod9910
Here is the pic.
Message 7 of 8
NicolasXu
Hi eod9910,
The Parameters command is only available for history-based modeling (aka parametric modeling). However, in your screenshot, it’s a history-free model (aka direct modeling). Fusion supports both ways.
In parametric modeling, you will see there is a timeline at the bottom of the application window. For your file, you may right click on the root node in the browser and convert the history-feel model to history-based model. For sure, only forward creation will be history-based.
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 8 of 8
eod9910
Thanks so much! That solved it!
