It should be at the very bottom:
Do you not see it there?
Jeff Strater (Fusion development)
sorry, but did you by any chance forget to add the picture? I certainly believe you that the command is not there.
One thing to try, use this command:
to reset your toolbar. If that doesn't work, try:
Jeff
Hi eod9910,
The Parameters command is only available for history-based modeling (aka parametric modeling). However, in your screenshot, it’s a history-free model (aka direct modeling). Fusion supports both ways.
In parametric modeling, you will see there is a timeline at the bottom of the application window. For your file, you may right click on the root node in the browser and convert the history-feel model to history-based model. For sure, only forward creation will be history-based.
Best Regards,
