- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
It seems putting User Parameters in dimensions has become much more difficult. I used to just type their name. Now there's a completion menu that appears, but if I try to just finish typing the name, F360 doesn't recognize it as a parameter. It requires that I select the parameter from the menu.
On top of that, if I hit the wrong key (which seems to be any key other than a letter key), it gives up and closes editing the dimension, leaving in place whatever was there before.
It's become very difficult to use.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
