第 1 条消息(共 29 条)
User Parameter Units
I plan on using user parameters to drive my design, so I am practicing with them.
I wanted to use one of the available units "%" which is under "Percentage" in the units drop-down when creating a user parameter. It does allow you to enter a value such as 50.
Unfortunately the Unit does not appear in the units column and you cannot use the parameter in a formula in a sketch dimension.
Of course there is a work around; select "No Units" and enter 0.5 as the value.
But it seems that the percentage units should work if they are in the list!
Am I doing something wrong?
