Can I annotate a design model image (.png) output?
mark
mark
I want to position a 3d model, add labels on the screen, like in drawings, and then export the screen to a .png file.  I can do this by outputing an image and then use a drawing app to add text to the imagee but that is painful and I have to do 10 or 20 of these.
Beyondforce
Hi @mark ,
I understand what you want, but unfortunately, you can't do that.
But, you can create a new sketch and use the Text command like annotation 😉
I hope it helps.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
