User Parameter being limited - how did he do it?
marc.pouliot.1
marc.pouliot.1
I create a three ring component which is meant to be used in other designs.
User parameters were, inner ring and outter diameters, clearance, thinkness.
It behaved ok, and now, I cannot access the user parameters screen ....
thanks
HughesTooling
I loaded your file and all seems OK, have you tried a reboot of your computer. Can you get a screen grab of your modify menu.
Mark
Mark Hughes
Owner, Hughes Tooling
nabarun.paul
Hi @marc.pouliot.1, Thanks for the post.
Is that you are not able to see the 'Parameter Dialog'?
If that is the case then this might help you - http://forums.autodesk.com/t5/design-and-documentation/parameter-menu-pop-up-missing/m-p/5859739#M35...
Thanks, Nabarun.
Nabarun Paul
Fusion Developer
marc.pouliot.1
Thanks !!
most of the time I work with 2 monitors, it worked fine on a single monitor...  but I lost my menu somehow...
I did not know about the Alt-Space on windows...
great, thks!!
