use a measured distence to create a prametred Cotation
M.andrieux99
M.andrieux99
i shearshed on google and diferente menu i didn't find an answer.
i would like to know, is this possible to set-up a parameter distence with a distance measured by ruler tool.
the goal of this option is to parater many distance to obtein a secondary distence who will be affected by the first one , and use this distence in a third step to creat off-set plan.
exemple
i would like to use the distence (1)
to set-up a parameter the "tangency off-set" value
and secondary question.
while creating a plan along a curve, is this possible to use a proportional option, with a + or - physical distence?
can e reverse the direction of the 0 and 1 point along distence?
thanks a lot.
Marc ANDRIEUX
jeff_strater
Today, there is no way to directly use the result of a Measure in a parameter equation.
However, you can create a "driven" sketch dimension, and use that value in another dimension, as long as it is within the same sketch.  I'm not sure if that will satisfy your requirement or not, but as long as it is all within the same sketch, it might.
Jeff Strater
Engineering Director
aliobidi
Hi ,
change unit to current for first question.
for secondary question , always first point of the sketch is 0 physical distance so you have to redraw the sketch but inverse
M.andrieux99
thank for anwser , i already use tricky way to use dimension to affect other stech, but unfortunaly this is not possible as i would like tu use it Thanks
hamid.sh.
@aliobidi wrote:
Hi ,
How does changing the unit to electrical current pertain to OP's question?
Hamid
