Uploaded reference images too small
tookemtoni
tookemtoni
Need to keep references images with fusion files but view is too small. This has been a problem for  a while. Any work arounds? See demo video and screen shot.
davebYYPCU
That is done with Canvas - Right click > Calibrate.
Select two, point positions and dimension them.  Graphic will conform to this request.
Might help...
jhackney1972
Along with Calibrate Canvas, you can use a sketch to help size the initial placement of the Canvas Image.  The Video will explain.
John Hackney, Retired
TrippyLighting
Are you inserting those into Fusion designs as Canvases, or do you want to keep them in the project folder for reference?
If the latter is the case, please post an example image. I will then re-post it as an improvement request on the Slack channel.
tookemtoni
Clarification: I mean just to view the document to read it. Not use it for a canvas or decal.
One workaround I just discovered is to turn it into a PDF but I'd prefer to skip that step step since our team uses screen shots in jpg, png or heic format. Attached is jpg image.
TrippyLighting
Done! We'll see what feedback we get!
tookemtoni
one work around is to convert image file type to a PDF. You will then get a scalable view in fusion teams web browser ,,,,It means extra work.... open image file, print as PDF, save in location.  I would still prefer not to have to think about that and just screen shot, upload and go!
