How do I copy rectangle in Fusion
pythoncontrol
pythoncontrol
Hey why it's so hard and not intuitive to copy a single rectangle?
I click on it i click CTRL+C like every normal human would do i click paste nothing happens.
I click on it i right click on it i select move and copy and it just unselects and I can do nothing.
How much is the autodesk lesson or course from advanced gurus who know how to copy element in this tool?
Why make your users life so hard?
@pythoncontrol Your post title was modified to add the product name to increase findability - CGBenner
TrippyLighting
Works fine here. Can you share a screencast of how you are attempting to copy/paste that rectangle?
CGBenner
@pythoncontrol
Hi, in addition to what @TrippyLighting has asked, can you share the file that is giving you trouble so the experts here can take a look?  Thanks!
Chris Benner
Warmingup1953
Copy and paste may not be the best way. Where are you up to on the learning Fusion journey? You asked about Autodesk lessons or courses?
jeff_strater
You probably need to understand a few basic things about rectangles in sketch.  There is no object that is a rectangle.  A rectangle is just a collection of lines, with some constraints applied.  There is no difference between a rectangle created by drawing 4 lines, and one created with the Rectangle command.  In fact, the Rectangle command is really just a UI shortcut to automate the drawing of those four lines.  In addition, the shaded are is a Sketch Profile, and is not the rectangle itself.  You cannot, for instance, copy and paste a Sketch Profile.  It is defined by the bounding geometry.  A profile is only selectable for commands like Extrude, Sweep, etc.
so, to copy a rectangle, you need to select the 4 lines that make up the rectangle.  The rest (constraints, profiles) will come along with the Paste.
You can copy a rectangle either by individually selecting the 4 lines, using area select (box select), or any other method.  However, there is one easy shortcut:  In sketch mode, double-clicking on any curve will select all the chained curves that that curve is attached to:
(view in My Videos)
Jeff Strater
Engineering Director
kacper.suchomski
I recently answered a similar question:
https://forums.autodesk.com/t5/fusion-design-validate-document/feature-request-copy-sketch/m-p/13804...
Kacper Suchomski
pythoncontrol
Thank you very much for detailed explanation for my ignorance.
