How do I copy rectangle in Fusion
pythoncontrol
pythoncontrol
Hey why it's so hard and not intuitive to copy a single rectangle?
I click on it i click CTRL+C like every normal human would do i click paste nothing happens.
I click on it i right click on it i select move and copy and it just unselects and I can do nothing.
How much is the autodesk lesson or course from advanced gurus who know how to copy element in this tool?
Why make your users life so hard?
@pythoncontrol Your post title was modified to add the product name to increase findability - CGBenner
TrippyLighting
Works fine here. Can you share a screencast of how you are attempting to copy/paste that rectangle?
CGBenner
@pythoncontrol
Hi, in addition to what @TrippyLighting has asked, can you share the file that is giving you trouble so the experts here can take a look?  Thanks!
Did your question get successfully answered? Then just click on the 'Accept solution' button.
Let us know how we did on Trustpilot.
Thanks and Enjoy!
Chris Benner
Warmingup1953
Copy and paste may not be the best way. Where are you up to on the learning Fusion journey? You asked about Autodesk lessons or courses?
jeff_strater
You probably need to understand a few basic things about rectangles in sketch.  There is no object that is a rectangle.  A rectangle is just a collection of lines, with some constraints applied.  There is no difference between a rectangle created by drawing 4 lines, and one created with the Rectangle command.  In fact, the Rectangle command is really just a UI shortcut to automate the drawing of those four lines.  In addition, the shaded are is a Sketch Profile, and is not the rectangle itself.  You cannot, for instance, copy and paste a Sketch Profile.  It is defined by the bounding geometry.  A profile is only selectable for commands like Extrude, Sweep, etc.
so, to copy a rectangle, you need to select the 4 lines that make up the rectangle.  The rest (constraints, profiles) will come along with the Paste.
You can copy a rectangle either by individually selecting the 4 lines, using area select (box select), or any other method.  However, there is one easy shortcut:  In sketch mode, double-clicking on any curve will select all the chained curves that that curve is attached to:
(view in My Videos)
Jeff Strater
Engineering Director
kacper.suchomski
I recently answered a similar question:
https://forums.autodesk.com/t5/fusion-design-validate-document/feature-request-copy-sketch/m-p/13804...
Kacper Suchomski
pythoncontrol
Thank you very much for detailed explanation for my ignorance.
