- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I just did a test uploading a STP file with a 1" cube, I set my defaults in Fusion to inches and used the data panel to uplaod the step file, when I open the file it opens in mm. If i use Create Design From File to open the STP file directly the new design is in inches. Seems like the upload from the Data Panel is defaulting to converting to mm.
STP file attached and temp f3d from the data panel.
Mark
Mark Hughes
Owner, Hughes Tooling
