Upload hanged, probably causing other issues as well
O.Tan
Advisor Advisor
Message 1 of 15
O.Tan
Recently I tried to upload a IGS file and not sure what happened but it's stuck half way, it seems there's no way for me to cancel it either. I believe this is causing Fusion 360 to fail to save new documents as well. This is the error message I got when trying to save a new drawing
Luckily I saved as .f3d, but at the moment, there's no way for me to save it into the cloud via Fusion 360.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Replies (14)
Message 2 of 15
ahsan.autodesk
Hi O.Tan,
Thanks for reporting the issue.
Can you please send us the last few AppLogFile*.log files from your machine? These log files may have useful data that can help us analyze the problem.
You probably already know this, but you can find them here:
    On Windows: C:\Users\<Windows User ID>\AppData\Local\Autodesk\Neutron Test Application\<A360 User ID>\
    On Mac: /Users/<Mac User ID>/Library/Application Support/Autodesk/Autodesk Fusion 360/<A360 User ID>
<A360 User ID> sub-folder name will be an alpha-numeric string with 12 characters, for e.g., EEZ9QQFUVTHM.
If you've been logging in using several A360 user accounts from the same machine, most likely you'll have multiple <A360 User ID> sub-folders. To know which sub-folder is the relevant one, I'm afraid you'll have to peek inside it and look for AppLog files with the appropriate time stamps. If you're unsure, please zip up all the ones that seem remotely relevant and send them to us.
Thx for your help
Ahsan (Fusion 360 Neutron Data Model)
Ahsan Ali
Fusion Senior Software Architect
Message 3 of 15
O.Tan
I've checked the Application Support folder but none of the AppLogFile is dated today.
Omar Tan
Malaysia
Message 4 of 15
macmanpb
About the dialog i can see you have a OSX Yosemite, right?
Is your Fusion an AppStore Version?
Message 5 of 15
O.Tan
Yeap, I'm using Yosemite
And yes, it's the App Store version. I wonder how to retrieve the log files cause I think apps from the Mac App Store stores it in a different location or something. The timestamps I have dates before pre-App Store version.
Omar Tan
Malaysia
Message 6 of 15
ahsan.autodesk
Hi there,
For those who have installed from the Mac App Store, you can find your App Log files here:
~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Autodesk Fusion 360/<A360 User ID>
Thanks and regards,
Ahsan (Fusion 360 Data Model)
Ahsan Ali
Message 7 of 15
O.Tan
Okay, this is the latest log file.
Omar Tan
Malaysia
Message 8 of 15
macmanpb
I think the issues are caused by network problems. Try to use an other DNS server (for example google 8.8.8.8 / 8.8.4.4). If you dont know how to change that, please search at google "google dns".
I hope that fixes the network issues...Smiley Happy
Message 9 of 15
O.Tan
Hmm, not sure if it's the DNS issue as it didn't occur when I first started using Fusion, it only happen after I used Fusion for a continuous 6 hours?
Anyhow, turning of the 2 reporting options seemed to solve it.
Omar Tan
Malaysia
Message 10 of 15
macmanpb
Have you the reporting options turned on or off?
Message 11 of 15
O.Tan
off and now Fusion closes properly. Though the hanged upload is still there. It only appears on my OS X side as logging in via Windows doesn't show the upload
Omar Tan
Malaysia
Message 12 of 15
O.Tan
Still unable to clear the upload, it's clearly stuck there as I've deleted the source as well.
Omar Tan
Malaysia
Message 13 of 15
ahsan.autodesk
Hi O.Tan,
I had looked at the AppLog files that you'd sent us previously. But unfortunately, they didn't point to anything out of the ordinary. It seemed that all the uploads that got started, eventually finished properly. But clearly, there is something amiss because you continue to see pending uploads.
At this point, to get you going, I suggest that you delete the following files from your disk:
~Library/Application Support/Autodesk/Autodesk Fusion 360
~Library/Application Support/Autodesk/MAC64/JobManager360
If you'd downloaded from the Mac App Store, I believe the folders will be under
Hopefully, that'll take care of your upload issues.
Ahsan
Ahsan Ali
Message 14 of 15
O.Tan
Thanks, though I find deleting just the JobManager360 folder seemed to do the trick 🙂
Omar Tan
Malaysia
Message 15 of 15
Thank you Ahsan! This actaully worked for me perfectly! Smiley Happy
