Unreliable sketch geometry in offset command
accountsEFWLY
Message 1 of 26
accountsEFWLY
I have this problem often: when I attempt to offset a closed perimeter it won't let me select all of the geometry.  This is extremely annoying.
See screencast:
model attached.
Replies (25)
Message 21 of 26
jhackney1972
If you have a particular Offset sketch issue, I would be glad to take a look if you want to attach it.  I know you do not want "workarounds" but sometimes that is what must be used until....
John Hackney, Retired
Message 22 of 26
TrippyLighting
@jhackney1972 wrote:
...  It seems to have been acknowledged by numerous Forum users so I am sure it has the attention of Autodesk.
I would not make that assumption at all!
However, it is very possible that this bug is already documented through another thread.
@jeff_strater could you please acknowledge this as a bug
Message 23 of 26
jeff_strater
This bug is FUS-82623.  It was first reported here:  offsetting-projected-sketch-lines
Jeff Strater
Engineering Director
Message 24 of 26
accountsEFWLY
So this has been known officially for over 9 months.
I've encountered this since about when I started using Fusion about 5 years ago.
Is anyone working to fix this?
Message 25 of 26
jeff_strater
this bug will be prioritized against other bugs and projects, depending on severity and number of people affected.  Unfortunately, I cannot comment on whether someone is actively working on this or not.
Jeff Strater
Message 26 of 26
juan.woodroffe
Hi Autodesk, any word on how this is going?? Related to this, is anything in the works for allowing the project/intersect feature to work off an actual sketch as a whole and not the specific lines that make it up? That way no matter how the sketch changes it still projects it and one doesn't need to redefine the projected geometries.
