Hi @MichaelaVallach
Thanks for posting! It looks like you are experiencing an issue in which dimension text in a Fusion 360 drawing is showing up as small boxes when output to PDF. We had an issue in which this occurred on Windows OS in the past, but it appears that it was addressed and resolved by our development team.
As you may be experiencing a regression of this issue, I wanted to gather some information from you. What operating system (Windows or Mac) are you working on? If you are working on Mac, did you download Fusion 360 from the Mac Apple Store or from the Autodesk Website? Also, what PDF viewer are you using to view the PDF? Is the text shown if you open the PDF with a web browser of Microsoft Word?
Also, are you using the default Arial text for the dimensions in your drawing, or have you changed the Annotation font in your drawing? Arial with a height of 3.5mm is the default in Fusion - will the text output properly at these defaults? To change the annotation text in a drawing please refer to the screenshot below. If the defaults are not outputting correctly, will a different font output to PDF?
It may also help our development team investigate this behavior if you could gather your diagnostic log files and attach them to your next post on this thread. We appreciate you bringing this behavior to our attention and I look forward to hearing from you!
Paul Clauss
Product Support Specialist
