move/copy question
move/copy question
move/copy question
This is a step-file
can i change the angle  of this "chamfer" with the move/copy command? or how can i do it?
i dont find a pivot-place where i can change this to my likings 😄
yeah i know, i can just delete this face and make a real chamfer, but i would like to know if it works with move/copy
jeff_strater
Hi @Anonymous,
Move won't do this for you, you are correct.  Instead, I would use Draft to change the angle of this cone:
Jeff
Jeff Strater
Engineering Director
HughesTooling
Don't think move will work to change the angle of a cone. If you want to edit the surface draft is the only option but that might mean creating a construction plane at the height you want to rotate the surface around.
Mark Hughes
Owner, Hughes Tooling
thank you 😄
we are just moving to fusion step by step, and my colleague joins from the S-Edge side.
he is moaning all the time what he could do in S-Edge. like this problem he only uses a move command and i was sure that fusion can do it that way, too 😄 but i failed to show him
